LMS 2.5.1 RME Inventory RME Collector Help!
I am unable to get the collection/inventory to work in RME 4.0.4
It gives me error when i check on validation credentials:
---None of the devices have credential verification data.---
When I check the logs it says: Device type not supported.
Job Type: Inventory Collection
Job Owner: admin
Status: Failed
Start Time: Sat Mar 29 15:36:35 PST 2008
End Time: Sat Mar 29 15:36:37 PST 2008
Schedule Type: Immediate
Device Summary
Device Details:
Total: 1
Scanned: 1
Pending: 0
Successful: No Changes: 0
Failed: 1
Successful: With Changes: 0
I can see in LMS both my switches setup with SNMP. I can view them in DFM and CS and they were
discover in Common services without issue. I have checked and double checked SNMP read string
and telnet ID and Password. Those are all working.
I have verified SNMP is working and can walk the SNMP tree.
Has anyone ran into this before? Any suggestions?
Joe Clarke Sat, 03/29/2008 - 17:54
First, RME 4.0.4 is quite old relatively speaking. You should consider upgrading to LMS 2.6 which currently includes RME 4.0.6. A lot of bug fixes and new device support have gone into this version. LMS 2.6 is freely downloadable from Cisco.com at http://www.cisco.com/kobayashi/sw-center/cw2000/lan-planner.shtml .
The error you're getting here points to the device not being supported by RME. What type of device is What is its sysObjectID?
Well it's happening on both switches.
Core- 4570r "bootflash:cat4500-entservicesk9-mz.122-31.SGA.bin"
Access Layer 3560G-48TS 12.2(25) =
I did find both switches in the supported doc.
How do I find the sysobject? I will try downloading LMS 2.6 and see what that does for me. Anyothe ideas?
Thank you for your help! Its much appriciated!
Joe Clarke Sat, 03/29/2008 - 18:45
You can get the sysObjectID by going to Device Center > SNMP Walk, and specify sysObjectID for the starting OID. You can then go to Common Services > Software Center > Device Updates and click on the number next to Resource Manager Essentials. In the pop-up that comes up, search for the sysObjectID (without the leading .).
Even if it says the sysObjectID is supported by doing that, you could have a package problem, especially if this is Windows. If you find this to be the case, you will need to uninstall and reinstall RME. But before you do that, you will need to set the TEMP and TMP per-user and global environment variables to something short like C:\WINDOWS\TEMP. You will also need to disable anti-virus software.
If this is LMS on Solaris, you could still have a package problem which will force you to reinstall RME, but you will not need to do any tasks before hand.
Joe Clarke Sat, 03/29/2008 - 20:32
It sounds like you do have a package problem. Since you've already moved to LMS 2.6, you will not be able to reinstall only RME. At this point, you should take a backup of LMS data, uninstall LMS, then reinstall LMS 2.5.1 (after doing the steps I mentioned in my previous post) then immediately patch to LMS 2.6, then apply the CS 3.0.6, RME 4.0.6, DFM 2.0.10, and Campus Manager 4.0.10 updates after that.
Once you upgrade to those versions, you will have all of the currently available device support.
The way you will know the device package installation is successful is that the .zip files in NMSROOT\MDC\tomcat\webapps\rme\WEB-INF\lib\pkgs and NMSROOT\www\classpath\com\cisco\nm\xms\psu\pkgs\rme are exactly the same.
Joe Clarke Sat, 03/29/2008 - 20:44
Because RME's package repository is corrupt. We see this all the time especially on Windows. It is typically the result of a bad installation.
I am getting the below but looks like SNMP is working. What packages do I need to download to support the 4570r and 3560G-48TS?
Name: Device Credential Verification Job Work Order
Summary: General Info
Job Id: 1043
Owner: admin
Description: ert
Creation Time: 29 Mar 2008 19:31:48
Start Time: 29 Mar 2008 19:31:48
Credentials Selected: Read Community, Read Write Community, Telnet.
Devices Selected:,
End Time: 29 Mar 2008 19:31:51
Device Name Read
Community Write
Community Telnet
1. Device Not Supported Device Not Supported Device Not Supported
2. Device Not Supported Device Not Supported Device Not Supported
Joe Clarke Sun, 03/30/2008 - 16:55
This error is usually a true positive, and means that the credentials entered in DCR are not correct for this device. If your protocol order is TELNET followed by TFTP, and telnet should succeed, check DCR to make sure the Username and Password credentials are correct for this device in addition to the enable password credential.
If they all check out, a sniffer trace should quickly show where the problem lies. You can also enable ArchiveMgmt Service debugging under RME > Admin > System Preferences > Loglevel Settings, re-run the job, and check the dcmaservice.log for errors.
Also when I run in Device Center:
TFTP fails. Could this be the issue? How to fix?
Management Station to Device:
Note: Protocol connectivity has been checked. Credentials for the protocol have not been tested.
Interface Found:
Status: UP
Test Results
UDP Okay
sent: 5 recvd: 5 min: 0 max: 0 avg: 0 timeout: 2 size: 64 protocol: udp port: 7
TCP Okay
sent: 1 recvd: 1 min: 0 max: 0 avg: 0 timeout: 2 size: 512 protocol: tcp port: 7
sent: 5 recvd: 5 min: 0 max: 0 avg: 0 timeout: 2 size: 33 protocol: http port: 80
TFTP Failed
sent: 5 recvd: 0 min: 0 max: 0 avg: 0 timeout: 2 size: 25 protocol: tftp port: 69
SNMPRv1/v2c Failed
sent: 5 recvd: 0 min: 0 max: 0 avg: 0 timeout: 2 size: 91 protocol: snmp_get port: 161
SNMPWv1/v2c Okay
sent: 5 recvd: 5 min: 0 max: 0 avg: 0 timeout: 2 size: 91 protocol: snmp_set port: 161
SSH Failed
Joe Clarke Sun, 03/30/2008 - 18:20
This indicates you have a bad SNMP read-only string configured in DCR for the device. That is a serious problem. You need to correct that credential. The fact that TFTP is failing simply means you have not enabled a TFTP server on the device. This is not used by LMS, so having TFTP fail is not a problem.
Joe Clarke Mon, 03/31/2008 - 21:22
The Data Collection filters have no bearing on traps or emails. They control which devices will be managed by Campus Manager. Therefore, I don't understand your questions.
Joe Clarke Fri, 04/04/2008 - 11:01
It sounds like you're moving into DFM and RME syslog analysis. Please start new threads for these questions.
Joe Clarke Sun, 03/30/2008 - 18:18
DFM alert identifiers are meaningless. You would need to drill into the alert to get the individual events and their details.
This means either the client can't connect to this device via telnet or the client browser is improperly configured to handle telnet:// URLs. Either way, it doesn't explain why config archive is failing.
