DSL Modem in Bridge Mode
Answered Question
Mar 29th, 2008
First off , when I use the word "work or worked" Im reffering to being able to get out on the internet.
Recently I was able to make an Embarq DSL modem work with a cisco router behind it. The modem however was NOT in bridge mode.
Now I want to make this work with the Modem in "bridge" mode. I have the Modem currently in bridge mode but I am unsure of the simplest way to setup NAT. Could someone look at this and reccomened a simple NAT config:
MODEM - Bridge Mode
WAN - fa0/0 67.234.34.76/18
LAN - fa0/1 192.168.1.1 255.255.255.0
LAN - 192.168.1.10 - 192.168.1.254
DHCP gives IPs to clients on LAN
Correct Answer by Paolo Bevilacqua about 8 years 11 months ago
If "worked", why not rate the post ?
A concise and effective config example also suggesting how to check on things. My rating, a '5'.
Overall Rating: 5 (3 ratings)
i-kendall Sun, 03/30/2008 - 02:50
Here you go. It assumes you also have a default route to the Internet.
interface fastEthernet0/0
ip nat outside
interface fastEthernet0/1
ip nat inside
ip nat inside source list 10 interface ethernet0/0 overload
access-list 10 permit 192.168.1.0 0.0.0.255
Any LAN ip that tries to go to the Internet will have it's source ip translated to the same as the WAN interface ip. You can look at a show ip nat trans command to see this has happened.
Hope this helps.
Correct Answer
Paolo Bevilacqua Sun, 03/30/2008 - 15:49
