DMA problem database validation failed
I ran DMA today to in order to foresee issues before the actual upgrade takes place which is in about 3-4 weeks -4.1(3) to 6.1-
I good a validation error:
The results are : Export - Successful. Validation - Failed.
I tried to look at the datavalidation.log file, but I cannot find it anywhere. It isn't there.
What other log can I look at? What could be wrong?
Any help will be greatly appreciated.
Thanks in advance.
gogasca Sun, 03/30/2008 - 00:45
Check for the following log files on the publisher where DMA has failed:
C:\CiscoWebs\DMA\Bin\*.log C:\Program Files\Cisco\Trace\DBL\installdb*.*
If there is any mention of the database failing validation look at installdbw1.log
Search for the string *Error* and use the following page to decode whatever Informix errors may be present.
All messages marked *Warning* can safely be ignored.
http://www.oninit.com/errorcode/index.php
I would recommend you opening a TAC case
since there are 1000 things which can be wrong
Just for reference:
For DMA install errors:
Check the following logs:
C:\Program Files\Common Files\Cisco\Logs\DMA\
C:\Program Files\Common Files\Cisco\Logs\DMA\DMAInstUI.log
C:\Program Files\Common Files\Cisco\Logs\DMA\\InstallUtils.log
C:\Program Files\Common Files\Cisco\Logs\DMA\IDSInstall.log
C:\Program Files\Common Files\Cisco\Logs\DMA\dbcmds.log
