IPCC Error 12005 agent login failed
Answered Question
Mar 30th, 2008
when I login to the agent desktop, the following error pops up.Login could not be performed.possible causes are invalid instrument, media termination problem or CM issue.
I have installed 7.0ctios client along with ctios 7.1.4 release.
One cause of this problem is incorrect configuration of the device target. Do you have the "/devicetype ciscophone /dn xxxx" set? Other possibility - the phone is not associated with the ICM JTAPI user in Call Manager. Show trace on the JGWY process and watch what it says as the PG tries to set up an observer on the device.
Why don't you upgrade the CTIOS client to match your CTIOS?
Geoff
Overall Rating: 5 (1 ratings)
Correct Answer
Geoff
Shalid Kurunnan... Tue, 12/06/2011 - 02:34
Hi Geoff,
We are facing the same kind of issue..
But here the issue is getting resolved when we deassociating and associating again in to the PG user.
Since it is occuring intermittently, we are facing problem.
So please let us know that can any one provide a solution for the same.
