DISA Implementation
Mar 30th, 2008
Hi all,
Currently implementing a DISA feature for a Customer.
However, I can only do it with a CUE.
Come across, using this in-built Script:
clid_authen_collect
However, my customer is using a PRI connection, so not very sure on how to implement this:
dial-peer voice 1 pots
application clid_authen_collect
destination-pattern 2000
port 1/0/0:15
What is the number 2000 refering to?
If using PRI, doing the above command, will it cause all external to internal call to use this TCL
Help appreciated,
Yen Lung
Overall Rating: 5 (1 ratings)
gogasca Sun, 03/30/2008 - 21:16
  • Green, 3000 points or more
Do you have CCM ?
We can do it with MobilityManager box or 6.X is built in.
If you dont
the dial-peer voice 1
should have incoming called-number 2000
to call the app if 2000 is the DID
yenlung Mon, 03/31/2008 - 09:49
had done:
dial-peer voice 3 pots
service clid_authen_collect
incoming called-number 1117
port 0/0/0:15
and
direct-inward-dial
port 0/0/0:15
both does not work for me. any idea ?
UCcomp2007 Fri, 04/04/2008 - 13:49
How can I change account and PIN for clid_authen_collect? script.
thank you
