PRI / Ethernet config
Mar 30th, 2008
Hi there,
I am looking to create a configuration to connect two PABX systems both with an PRI module in it via Cisco routers (with also VWIC-E1/T1 modules in it) over ethernet to eachother. So the PABX systems can communicate with eachother. Can somebody give me a clue where to start ? I looked on the Cisco site but really cannot find the right configuration documents.
mamkreutz01 Sun, 03/30/2008 - 22:32
Hi there,
The two PABX systems are not VoIP as far as i know. They are only equipped with PRI modules (E1). Do the dial-peers need to be entered at the Cisco routers then or at the PABX systems ?
Avner Izhar Sun, 03/30/2008 - 23:16
In the routers, everything I referred to is configured in the routers.
HTH, Avner.
