ACE - Do I need a L7 policy to configure L4 load-balancing
Answered Question
Mar 30th, 2008
Hi - I simply need to load balance TCP traffic to a specific port to 2 servers in a serverfarm. There is nothing in the documentation that states how to associate a serverfarm with a policy. The only documentation I can find which explains how to associate a serverfarm with a policy is if you configure a L7 policy - Do I need to configure a L7 policy even if I just want to do L4 load balancing?
I'm sure I must be missing something simple but I've been through the docs at length and I cn't find any config examples on CCO
Many Thanks, Dom
Correct Answer by ciscocsoc about 9 years 3 months ago
Hi Dom,
You should only need a L7 policy if you are doing L7 inspection.
The skeleton config should be something like:
class-map match-all VIP
match virtual address 192.168.1.100 any
policy-map type loadbalance first-match LB-POLICY
class class-default
serverfarm FARM
policy-map multi-match VIPS
class VIP
loadbalance vip inservice
loadbalance vip LB-POLICY
(assuming that FARM is defined and the service policy applied to the interfaces)
If you look at the "getting started" guide there is a simple LB config in that. Although it does refer to an L7 policy it is more like an L4.
Cathy
Overall Rating: 5 (2 ratings)
Correct Answer
ciscocsoc Mon, 03/31/2008 - 05:44
  • Silver, 250 points or more
Hi Dom,
class class-default
serverfarm FARM
class VIP
Cathy
Gilles Dufour Mon, 03/31/2008 - 08:13
  • Cisco Employee,
Cathy, looks like you became a pro of the ACE module :-) !!
Gilles.
d-fillmore Tue, 04/01/2008 - 08:36
Thanks Cathy - I raised a TAC case in the ned as I needed to know on Monday.
It's the fact that the documentation doesn't say that you need a L7 policy to do basic L4 load-balancing.
Many Thanks for your help =)
