mpls switching for a home lab
Mar 30th, 2008
is it possible to set up a home lab with one router acting as a mpls switch? I know this can be done for frame-relay but what about mpls?
Overall Rating: 5 (1 ratings)
evsrajatgupta Mon, 03/31/2008 - 07:50
Hi rajibchicago,
MPLS work both in frame and ATM mode with a little configuration difference.
You can configure MPLS by enable them on the interfaces of the router provide your IOS support Cisco express forwarding and MPLS
Command
In the configuration mode
IP CEF
In the interface mode
MPLS IP
MPLS label protocol LDP
It is simple but to understand the functioning of MPLS you need 3 to 4 level 3 devices.
Please Rate
