Factory Defaulting 4402
Mar 30th, 2008
We have a lab controller (4402) that no one seems to know the password for. Is there a way to do a factory reset without having been logged in first?
i don"t mind losing the existing configuration>
Scott Fella Sun, 03/30/2008 - 20:45
I believe you can reboot the WLC while you are consoled in and then during boot up there will be a prompt to hit 'ESC'. There should be an option to reset the WLC to facory or maybe it is clear configuration. hope this helps. Haven't done this in a while.
Matthew Fowler Sun, 03/30/2008 - 23:10
Connect to the console and reboot the WLC. After it's finished loading, at the username prompt, type 'Recover-Config'.
By the way; a distant relative perhaps ;)
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
