Route map question
Mar 30th, 2008
May i know wat doe sthe below command mean?
network A.A.A.A mask B.B.B.B route-map community-no-export
route-map community-no-export permit 10
set local-preference 100
set community 100:12345 no-export
access-list 10 access-list 10 permit 64.220.221.96 0.0.0.31
Does the above mean the below.
- Take ip that is permit by access list 10 and apply the route map and advertise it out?
Please help
Does the above mean
Danilo Dy Sun, 03/30/2008 - 21:35
The answer is NO.
The route-map has a "set" parameters but no "match" parameter
However, since you have the line "network A.A.A.A mask B.B.B.B route-map community-no-export" this means the route-map "set" parameters applies to this network "A.A.A.A/B.B.B.B". When the router announce this prefix to its neighbor, it will have those attributes set in the route-map.
You can see it by checking what is being advertised to your peers. i.e.
show ip bgp neighbor peer_ip_address advertised-routes
regards,
Dandy
caijunjie Mon, 03/31/2008 - 10:14
Thanks for the reply, u are right, i had get access list and route map mix up.
Alan
