CCME license
Mar 30th, 2008
Dear sir
i wanted to know do i need license for CP-7906G,Cp-7940G and for Ip communicator ? I am using CCME as a call processing agent.if yes what are the license part number for 7906 ,7940G and specially for Ip communicator . as i didnot find any thing about ip communicator license for CCME
royalblues Mon, 03/31/2008 - 01:06
  • Green, 3000 points or more
Whenever you buy an IP phone, the license is also ordered as part of that.
I think for the communicator it is
SW-CCME-UL-IPCOMM= Single CallManager Express Unit License for IP Communicator
For 7906 and 7940G they should be
SW-CCME-UL-7906 and SW-CCME-UL-7940
I am not sure whether legally the license bought for CCM can be used with CME
Narayan
zeeshan2007 Mon, 03/31/2008 - 01:24
thanks , i have one more question do i need license for 7914 (expansion module)?if yes which one.
thanks again for your prompt response
James Hawkins Mon, 03/31/2008 - 05:31
  • Blue, 1500 points or more
No extra license is required for the 7914 for either CCME or CCM.
You do obviously have to purchase a license for the phone to which it attaches.
