Nokia N95 with CCME-SIP
Mar 30th, 2008
Hi all,
I am trying to register my Phone (Nokia N95) with our CCME router. have anyone successfully set up this phone with CCME?
I have configured SIP on my CCME but it seems that there is a problem since I am getting some errors when I try to register the Phone (CCME Version 4.2)
Phone firmware/software is updated to the latest one ( ver 21...)
Here is the router config of the router
voice register global
mode cme
source-address 192.168.100.100 port 5060
max-dn 192
max-pool 58
timezone 44
dst start Oct week 8 day Sun time 02:00
dst stop Mar week 8 day Sun time 02:00
create profile sync 0005043018158482
voice register dn 1
number 260
name N95
voice register pool 1
id mac 001A.DCE2.E66C
number 1 dn 1
username **** password ****
codec g711ulaw
Debug output
Mar 31 04:30:26.223: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.100.100;transport=UDP SIP/2.0
Security-Client: digest
Via: SIP/2.0/UDP 192.168.17.10:5060;branch=z9hG4bK0jrrn6bc39hc7ui90buk4af;rport
From: <sip:[email protected]>;tag=c3obn6eodhhc682q0buk
To: <sip:[email protected]>
Contact: <sip:[email protected];transport=UDP>;expires=3600
Require: sec-agree
Proxy-Require: sec-agree
CSeq: 803 REGISTER
Call-ID: e5WXCr21oIeWhgbZgLh3ujuWQ7Zrk_
User-Agent: Nokia RM-159 V 21.0.016
Max-Forwards: 70
Content-Length: 0
Mar 31 04:30:26.227: //-1/xxxxxxxxxxxx/SIP/Error/sipSPICheckRequest: CheckRequest fail on method 100 error code: 6 and status: 420
Mar 31 04:30:26.227: //-1/xxxxxxxxxxxx/SIP/Error/act_idle_new_message: Failed check request
Mar 31 04:30:26.227: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 420 Bad Extension
To: <sip:[email protected]>;tag=9D1CCC-E56
CSeq: 803 REGISTER
Unsupported: sec-agree
Reason: Q.850;cause=100
Content-Length: 0
Nour
jsivulka Thu, 04/03/2008 - 14:35
  • Bronze, 100 points or more
Could you please configure the following and then reset the SIP phones and see if it register:
voice service voip sip registrar server
(config)#voice register global
(config-register-global)#create profile
(config-register-global)#end
Please run the following debugs then make a failed call and send me the capture:
un all
debug ccsip message
debug ccsip error
debug voip ccapi inout
Also you need to do "create profile" under voice register global and then either reset the phone or reset the phone under
"voice register pool" if the phone is registered.
mnour401917_2 Thu, 04/03/2008 - 17:56
Hi jsivulka,
Thank you for your reply
I have attached the requested Debug and also added the (create profile) command.
Thanks heaps for your help.
