CDP on ASA 5510
Answered Question
Mar 31st, 2008
hallo,
How can i ENABLE CDP on ASA 5510.
thx
Correct Answer by francisco_1 about 6 years 2 weeks ago
CDP is not supported on ASA or PIX. What you can do is speak to cisco about it if you need it. maybe they can make it available on the next ASA software version.
Please rate if this helps.
Franco
Average Rating: 5 (3 ratings)
shrikar.dange Mon, 03/31/2008 - 01:22
AFAIK CDP is enabled by default on all cisco platforms.You can enable it manually in global config mode with following command:
Router(Config)#cdp run
But in case of ASA it is not enabled by default(In my knowledge).Also it depends on the Software version you are running.
Please chk this URL:
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/index.htm
HTH,
regards,
shri :)
aadilovic Mon, 03/31/2008 - 02:23
I was try everything but with no success.
any other suggestions?
thx
Correct Answer
francisco_1 Mon, 03/31/2008 - 03:05
Franco
Login or Register to take actions
Posted March 31, 2008 at 1:13 AM
Stats:
Replies:5 Avg. Rating:5
Views:8881 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
1 15,007
2 8,150
3 7,725
4 7,083
5 6,742
165
82
69
65
55
