SSH and Telnet
Mar 31st, 2008
Hi All,
I have just upgraded my WS-2960G-48TC Switches, enabled SSH but I can access the Switch using both protocols - how can I disable Telnet and permit SSH
royalblues Mon, 03/31/2008 - 02:01
Under VTY config configure transport input ssh
line vty 0 4
transport input ssh
This will disable telnet on the vty lines
spangdahlemcco Mon, 03/31/2008 - 02:04
The above two messages are correct. However, you will need to type that command on vty 0 15 as well to ensure all vty lines require ssh connections.
Goutam Sanyal Mon, 03/31/2008 - 02:06
Hi Michael Buskin, With the addition of Narayan's post I'd like to suggest you to put " transport input all" under line vty 0 4. Thanks Goutam
royalblues Mon, 03/31/2008 - 02:09
Transport input all would enable telnet on the VTY lines which the user wants to disable :-)
Goutam Sanyal Mon, 03/31/2008 - 02:16
Hi Narayan, thanks you are right, just ignore the “disable telnet” I was sleepy. :) Thanks Goutam
