VLAN help needed
Mar 31st, 2008
Hi, I've setup a AP521 access point, and now it asked for a VLAN number. I'm sort of gren into larger networking, but currently Im the only one in the company responsible for it, so I learn a lot by the hard way each day ;)
I dont know what to do with the VLAN number, but in the topology view I can see a Cisco 831 router.
Could anyone give me some guidelines on this?
Thanx in advance.
Justin Brenton Mon, 03/31/2008 - 09:30
  • Silver, 250 points or more
Hi granzow12,
A Vlan is a virtual network. Basically you need to find out what virtual network you would like your access point to be a member of.
For example: You may have a Vlan of 21 for Voice, Vlan 20 for Data. Basically 2 seperate networks.
I would suggest looking at the running-configuration of your Cisco hardware to find out your Vlan information on your network.
HTH, Please rate
Justin
granzow12 Mon, 03/31/2008 - 22:59
Okay, I see.
But we dont have any other cisco hardware than our router. Does the VLAN option require Cisco hardware?
Thanx in advance.
