Boot Loader upgrade query
Mar 31st, 2008
Hi All,
I've upgraded a 3750 integrated controller and a 4402 to 5.0.148.0 (s/w and bootloader image) but the sh sysinfo ouput still reports the previous bootloader version:
Product Version........... 5.0.148.0
RTOS Version..... Linux-2.6.10_mvl401
Bootloader Version.......... 4.2.61.0
Have I missed a step, or is there some other problem?
Thanks for any help
Scott
Overall Rating: 3 (2 ratings)
dennischolmes Mon, 03/31/2008 - 04:02
I'm not sure why you'd still show the 4.2 boot loader. What order did you install them in? Did you do a second reboot to confirm that it was still showing 4.2.61? When you loaded both ER and AES did you disable both radio networks and all wlans? What do you show if you do a "show run-config" ?
scottwilliamson Mon, 03/31/2008 - 04:27
Hi Dennis,
I upgraded the 3750 first - uploaded both images, disabled the WLANs and rebooted the box. Checked the sysinfo and saw the discrepancy - tried downloding the ER file again and rebooted but no difference.
With the 4402 I rebooted after downloading the s/w then repeated with the boot image - Same result - bootloader still previous version. This time I forgot to disable the WLANs though.
The run-config output reports the 4.2 bootloader.
I did notice that when I was upgrading the 4402 via it's own GUI it was referring to the "emergency bootloader", could this be significant?
Scott
dennischolmes Mon, 03/31/2008 - 04:44
This ER release only fixes a very minor caveat but I would call TAC just to make sure what happened. Is should show the proper code version. I don't think you have anything to worry about.
Scott Fella Mon, 03/31/2008 - 04:49
That is a known issue regarding the bootloader. Even though you load the bootloader, it will still show the original. This info was from TAC... no date when this would be fixed since the boot loader file isn't always an upgrade to the boot loader, but to the partition. TAC also mentioned that when opening a case that this be noted... if the boot loader was installed or not, or which bootloader was loaded last. Hope this clarifies things.
scottwilliamson Mon, 03/31/2008 - 04:53
Thanks Dennis, Fella5,
I'll leave it be until a new bootloader is released.
Cheers,
Scott
Trending Topics - Security & Network
