03-31-2008 03:19 AM - edited 03-05-2019 10:04 PM
I've got a Cisco 3660 which doesn't show installed NMs when 'show diag' is issued. It has a NM-1FE2W & a NM-4T installed.
sh diag, sh diag 0, sh diag 1 & sh diag 2 all show the same thing.
sh diag:
3660 Chassis type: ENTERPRISE
3660 Backplane EEPROM:
Hardware Revision : 1.0
Top Assy. Part Number : 800-04740-02
Board Revision : C0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : HAD06311026
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Chassis Serial Number : JHY0636K4SX
Chassis MAC Address : 000a.415b.2680
MAC Address block size : 112
Manufacturing Test Data : 00 00 00 00 00 00 00 00
Fab Part Number : 28-2651-02
Number of Slots : 6
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 C8 41 01 00 C0 46 03 20 00 12 84 02
0x10: 42 43 30 80 00 00 00 00 02 02 C1 8B 48 41 44 30
Any thoughts?
Geoff
PS - show ver:
Cisco IOS Software, 3600 Software (C3660-IS-M), Version 12.4(13), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 22-Feb-07 20:41 by prod_rel_team
ROM: System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
C3660 uptime is 0 minutes
System returned to ROM by reload
System image file is "flash:c3660-is-mz.124-13.bin"
Cisco 3660 (R527x) processor (revision 1.0) with 251904K/10240K bytes of memory.
Processor board ID JHY0636K4SX
R527x CPU at 225MHz, Implementation 40, Rev 10.0, 2048KB L2 Cache
2 FastEthernet interfaces
4 Serial interfaces
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
03-31-2008 04:30 AM
Hi Geoff,
Are these NM's working?
If so, are you able to see them if you type "show inventory" instead?
If not, do you have another router you could try them in, to test whether the NM cards are faulty?
Hope this helps
Graeme
03-31-2008 04:51 AM
#sh inventory
NAME: "3660 chassis", DESCR: "3660 chassis"
PID: , VID: 1.0, SN: JHY0636K4SX
NAME: "c3660 Motherboard with Fast Ethernet", DESCR: "c3660 Motherboard with Fast Ethernet"
PID: Leopard-1FE , VID: , SN: JAD06310CNA
NAME: "TDM0", DESCR: "TDMSlot"
PID: TDMSlot , VID: , SN:
NAME: "FastEthernet/WAN", DESCR: "FastEthernet/WAN"
PID: NM-1FE2W= , VID: 1.0, SN: JAD060701A9
NAME: "Four Port High-Speed Serial", DESCR: "Four Port High-Speed Serial"
PID: NM-4T= , VID: 1.1, SN: 21412612
The cards are working fine and there's nothing odd with the router as far as I can see, except for sh diag.
03-31-2008 04:31 AM
Since you are running a very recent code, can you try sh inventory to see whether it shows up something
Narayan
