Computer does not get a IP address after a 7961 Phone
When a Computer is attach to a IP phone 7961, some times it will not get a IP address when the comupter boot.
it is possibly to fix the problem if the computer is direckly attach to the wall jack it will get a Ip address and it will still get a Ip address if it is attach to the phone again.( I the IP phone is unattach from the wall jack and attach again the computer will not get a Ip address)?
matthewpage Mon, 03/31/2008 - 03:59
  • Bronze, 100 points or more
Could you send the config your using on the switch port??
interface FastEthernet0/33
switchport access vlan 150
switchport mode access
switchport voice vlan 50
mls qos trust dscp
dot1x mac-auth-bypass
dot1x pae authenticator
dot1x port-control auto
dot1x timeout quiet-period 1
dot1x timeout tx-period 1
dot1x reauthentication
dot1x guest-vlan 250
dot1x auth-fail vlan 250
spanning-tree portfast
matthewpage Mon, 03/31/2008 - 10:33
This seems like a dot1x issue. When you hit the issue can you check that the dot1x has authenticated the port?? i think the command is show dot1x interface fax/x detail.
Also if your using mab there is a known issue that the DHCP times out before its been authenticated. Work around for this is to release, renew the ip address.
I will also try your config out on my switch tomorrow. Are you using ACS or IAS as your radius server??
joepapesh Mon, 03/31/2008 - 20:00
What version of phone software are you running? It may be impacted by this bug...
CSCse08120 Bug Details Bug #12 of 27 | < Previous | Next >
7961 - PC cannot see data traffic if PC Voice VLAN Access is disabled
Symptom:
PC plugged at the back of a 7961 cannot get its IP settings from DHCP
Conditions:
option "PC Voice VLAN access" is disabled in CCM device configuration (default is "enable" )
Workaround:
re-enable the "PC Voice VLAN access" option
matthewpage Tue, 04/01/2008 - 01:25
So first are you seeing the port as being authorised when you see this issue??
