Obtaining S/N remotely
Mar 31st, 2008
Hello there
I hope I'm asking this in the right place... I'm having trouble obtaining the chassis serial number remotely from Cisco 1760 routers. Both sh ver and sh diag provide the PCB S/N, not the chassis S/N that is used to identify the product to Cisco.
Is there anything I am missing here? Is there actually a way to remotely obtain the chassis S/N from a Cisco 1760 running 12.4(12b)?
Thanks in advance for any assistance on the matter.
dorian.negru Mon, 03/31/2008 - 05:06
Like I mentioned above, both SHOW VERSION and SHOW DIAG do NOT provide the chassis S/N - instead, they provide the PCB S/N which is useless when it comes to identifying the product to Cisco.
Richard Burts Mon, 03/31/2008 - 06:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dorian
On some routers, most especially the ISR routers in my experience, the command show inventory will show the chassis serial number. Unfortunately there are some routers that implement the command but that do not return the correct serial number. I do not have a 1760 to test it on. You might give show inventory a try and see if it works for your 1760.
Rick
dorian.negru Mon, 03/31/2008 - 07:10
Thanks for the tip!
Unfortunately the returned serial for the chassis is (incorrectly) reported to be the same as the motherboard serial. I guess this particular platform is bugged when it comes to chassis S/Ns.
Richard Burts Mon, 03/31/2008 - 08:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Dorian
Unfortunately I believe that you are correct. It is too bad that Cisco is putting more emphasis on identification by serial number without providing a good reliable way to determine this serial number remotely.
Rick
royalblues Mon, 03/31/2008 - 12:04
  • Green, 3000 points or more
I think Cisco have started this with the new ISR routers...it is just that the old routers do not work the same way
One of the best practices would be to configure snmp-server chassis-id
later on you can retrieve them via sh snmp server
Narayan
