ASA 5505
Mar 31st, 2008
Hello.
I have a cisco ASA5505 and am unable to login to it via http or asdm... The device is up and operational but remote access isn't available. Are there any steps i can take to restart the remote access services without rebooting the device itself? If so what would they be?
Thank you.
Jamie.
i-kendall Tue, 04/01/2008 - 03:22
Jamie,
It is possible you have either blocked access, or removed the commands that allow HTTP.
http server enable
http {your inside subnet}{and mask} inside
also I think you need
asdm image disk0:/{asdm filename}
asdm history enable
I think you need the first, but the second one is optional. Try it without these first, and see if it works, then try it with them.
Hope this helps.
Iain
