ipsec disconnection over mpls
Mar 31st, 2008
Our customer has mpls connectivity between two sites. And also he configured ipsec site-to-site vpn between those two sites. IPSec tunnel is going down after 1 hour idle time even sa is set to default value. Is there any problem with mpls network for ipsec.
skrao
shivlu jain Mon, 03/31/2008 - 06:48
  • Silver, 250 points or more
skrao
had you tried the gre tunnel
regards
shivlu
sivakondalarao Mon, 03/31/2008 - 06:58
Hi Shivlu,
Thanks for your response. GRE tunnel is required?
Customer is not running dynamic routing protocol with service provider, it is default static routing.
skrao
