cme h323 transfer to voice mail
Mar 31st, 2008
Have CME system. Internally works fine transferring to voice mail on busy or noan. PSTN calls to system, likewise no problem. Have a pbx connected via t1 at another site using voip to get calls to cme. Calls work find however on busy or noan disconnect rather than transfer to voice mail. I have allow connections coded for h323 to sip and sip to h323 but it doesn't appear to work. Thoughts thks.
whanson Mon, 03/31/2008 - 08:29
sorry, got a hint from another forum. Issue is 711 to 729 transcoding
rogerpeterson Thu, 10/09/2008 - 22:17
What did you need to do to resolve the issue? I have the same situation and I've been hitting my head silly trying to figure it out.
slongewa Fri, 10/10/2008 - 05:16
Well, I can't comment on his problem specifically, but most of the time, you need to assure that the dial-peer going to your CME specifies the codec g711ulaw and that your session protocol on the dial peer is sipv2. So you'd have something like the following:
dial-peer voice 2000 voip
destination-pattern 5000
session protocol sipv2
session target ipv4:x.x.x.x
dtmf-relay sip-notify
codec g711ulaw
no vad
If you're after something additional in regards to the transcoding let me know, but I think this should point you in the basic direction to start with.
