03-31-2008 07:51 AM
On my LMS 3.0 under the Best Practices Deviations i got the following message:
BPDU-Guard disabled on access ports
When i check the config of the according switch i see that bpdu-gard is enabled by default.
spanning-tree mode pvst
spanning-tree portfast default
spanning-tree portfast bpduguard default
spanning-tree portfast bpdufilter default
interface FastEthernet0/1
switchport access vlan 27
switchport mode access
no ip address
no logging event link-status
no snmp trap link-status
no cdp enable
Can anyone explain to me, why LMS tells me to configure bpdu-guard on every interface seperately?
thanks a lot!
Solved! Go to Solution.
03-31-2008 12:18 PM
We stopped looking at the Physical Discrepancy and Logical Discrepancy reports produced by Campus Manager since LMS 2.2 because of this issue. The bottom line is LMS is just not sophisticated enough to know all the assorted configuration possibilities. So LMS ends up producing these false-positives unless it sees the switches are configured only the way it deems "correctly"--apparently per-interface BPDU guard in this instance. In short, simply ignore it.
03-31-2008 09:27 AM
What type of device is this?
04-01-2008 02:07 AM
It's a 3560 48Port Switch running c3560-ipbase-mz.122-25.SEE3.bin
03-31-2008 12:18 PM
