load balancing on a Redundant Bridging
Mar 31st, 2008
Hi to all,
i need to configure a wireless link using two bridge on a single side of the link(4 bridge total),i want to aggregate wireless link with Redundant Bridging but i don't know if the bandwidth is 54mbit or is double?!?
There is a hint or a method to double the bandwidth of a link using aironet bridge?(wireless-g)
Thanks and best regards,
Carlo S.
Scott Fella Mon, 03/31/2008 - 10:41
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You really won't get 54mbit more like half... because of the overhead.
If you use two birdges on both ends, you can either load balance via vlan priority or you can etherchannel the links and let etherchannel load balance depending on what you set it to.
You really can't double your bandwidth by adding more links. If you need more bandwidth per link, then you will have to go another route besides Cisco.
daysleeper Mon, 03/31/2008 - 11:29
using etherchannel on a wireless link is useful only for a redundant link? The speed of link don't change in any case?
The only wireless n equipment i found on cisco site is 1250 but is a equipment for indoor use and is not a bridge...is a access-point and i'm not sure it can use directional antenna.
Thanks for your help.
Scott Fella Mon, 03/31/2008 - 11:32
  • Hall of Fame,
    2017 Wireless
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
