03-31-2008 08:33 AM - edited 03-05-2019 10:04 PM
Hi to all my respected friends and gurus,
You guys have saved my butt numerous times - and i thank you all for that. Here's another one for you. I had a customer that couldn't reach his switch (2950)and we deduced that he may be running a standard image instead of an enhanced one. He's now asking me whether the enhanced image will support power over ethernet. i was under the impression that the IOS revision wouldn't make a difference - any clarification on that?
The IOS is 12.1 (6) by the way...
03-31-2008 08:46 AM
You are correct. that model of switch does not support Power over Ethernet. You need to upgrade your hardware.
2960s do support POE
03-31-2008 09:12 AM
What about if he's using a "power injector?" (I don't know what one is but i heard someone saying that they managed to use POE with a power injector and some form of manual configuration)....
03-31-2008 09:16 AM
That is an option, but depending on how many phones you have, this could be a maintenance headache.
Here is some Q and A on the injector.
03-31-2008 09:23 AM
Thanks for all your help there Matt and i appreciate the swift reply. Please see the reflection in the ratings...
03-31-2008 09:30 AM
No problem and thanks for the kind rating. I hope that you have gotten all of your questions answered.
