802.11n AP installation
Mar 31st, 2008
My understanding of spatial multiplexing is that the separate data streams are better understood by the reciever when multipathing in the RF environment is high. If this is the case then to ensure multipathing, line of site between AP and STA should be avoided. Should I therefore aim to install a 1250 AP behind metal to get the best performance?
Terry
Scott Fella Mon, 03/31/2008 - 10:22
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
No...... 'N' works better in areas where there is mulitpath, but doesn't mean you should introduce multipath.
Place AP's like you would if you were running 802.11a/b/g.
Scott Fella Tue, 04/01/2008 - 08:24
  • Hall of Fame,
    2017 Wireless
Just remember.... multipath is still your ememy:)
ED CARMODY Sun, 04/06/2008 - 05:16
fella5, i heard exactly the opposite from Cisco. My takeaway from one of the 11n technical training sessions was that the traditional rules of AP placement were turned upside down...11n NEEDS multipath for optimal performance...we were told the more the better...
Scott Fella Sun, 04/06/2008 - 06:09
  • Hall of Fame,
    2017 Wireless
I was at the 11n training session also and the BU told us that we should survey the same as if you were using a 1242 or 1131. 11n uses multipath to provide better signal at a greater distance, but provides the same coverage. 11n is a draft and that helps in a multipath environment, but unless you have 'N' enabled on the AP and clients are all 'N' enabled, 802.11b/g and 802.11a environment will still have issues with multipath. So in short, they want to use the 1252, but most likely will still have normal 802.11b/g/a clinets.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
