PIX 515E
Mar 31st, 2008
My goal is :- we want port 25 from specific outside addresses ( 208.75.194.0/21) to be allowed to: my1.cbc.com (notes) and mys.cbc.com (notes1)
This is my partial config
name 10.101.91.14 Notes1
name 10.101.91.13 notes
name 208.75.194.0 Mx_logic
object-group network Mx_Logic_Notes
description MxLogic networks to Notes
network-object 208.75.194.0 255.255.248.0
access-list outside_acl permit tcp object-group Mx_Logic_Notes host 69.191.66.229 eq smtp
access-list outside_acl permit tcp object-group Mx_Logic_Notes host 69.191.66.230 eq smtp
static (inside,outside) 69.191.66.230 10.101.91.14 netmask 255.255.255.255 0 0
static (inside,outside) 67.109.66.231 10.101.91.13 netmask 255.255.255.255 0 0
access-group outside_acl in interface outside
When I issued Pix1# sh access-list both access-list has (hitcnt=0)
What am I doing wrong.
do I need to specify port eq 25 on the source also ?.
help
Overall Rating: 5 (1 ratings)
dhouser Mon, 03/31/2008 - 15:29
I think you might want to look at the public IP's. They dont all match between your static's and your ACL
tdalago911 Mon, 03/31/2008 - 18:06
it was just a typo
static (inside,outside) 69.109.66.230 10.101.91.14 netmask 255.255.255.255 0 0
sureshkum Mon, 03/31/2008 - 23:44
Your config seems to be fine.checkout the typo errors once again.Make sure the routing and make sure the outside public ip not a porxy ip of their end.
dongdongliu Tue, 04/01/2008 - 01:22
hi,
I am not sure but pls check out about communication between 208.75.194.x and 10.101.91.x that only need port 25, how about 1352 ?
regards
dongdong
