MGCP with PRI
Mar 31st, 2008
Dear sir
I wannted to know that i m using MGCP with 2 PRI's . i want to fix some channels for inbound call and same for outbound call on PRI 1 same thing with my PRI2. is it possible if yes how ? and same with H.323 ?
it will be very appreciating for me
thanks waiting for yr prompt response
zeeshan2007 Tue, 04/01/2008 - 22:21
sir
cannt we select channels in mid for outbound calls, for example ch5 to ch15 etc ? or can we select channels start from ch1 to ch10 for outbound. and ch11 to ch 23 will remain for inbound ?
yr response will really help me alot.
paolo bevilacqua Wed, 04/02/2008 - 05:56
  • Hall of Fame,
    Founding Member
Hi, you asked this question on other threads already, but you never clarified why or what problems are you trying to solve.
