Service to dial Speech Connect number
a.baird Tue, 04/08/2008 - 13:24
Hi.
I messed around with this very thing a while back but I didn't get as far as I wanted, before I was pulled into other things. You should be able to create an IP PHone service that will instruct the phone to dial any number. Take a look at the developement guide. Specifically I think you should be able to create a simple xml script that will send the phone a Dial instruction when a key is pressed. Here is a link to the guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/all_models/xsi/6_0/english/programming/guide/XSIbook.html
Take a look specifically at the chapter 'Internal URI Features'.. look for the Dial URI.
I hope to spend some time on this in the near future.
-Adam
a.baird Wed, 04/09/2008 - 10:30
Hi again.
I've been able to do this today. Here is an example of my xml app that causes the IP Phone to dial Speech Connect at ext 1001:
<?xml version="1.0"?>
You just need this script to be executable on your web server, then configure the CallManager with the url that points to this script as a service. Then associate the service to the phone.
