Ring Out, Connected, but no ones home.
Mar 31st, 2008
Problem: Calls placed, the number can be dialed on/off hook, the display will indicate Ring Out and then Connected, but nothing is heard--no digits dialing, no party on the other end, etc. But the called party can hear the caller. Sometimes takes anywhere from 1-3 times to get call to go thru.
Also happens occasionally on inbound calls. We can receive the call and hear the caller, but they cannot hear us.
System Setup:
Pub & Sub=Cisco MCS 7825H
1GB memory
MCS Version
CCM-CSA Policy 1.1(7)
CSA Agent 4.0.2.629
OS Image 2000.2.4
OS SR 2000.2.7sr8
OS Upgrade 2000.2.7
CCM Sys Ver 4.0(2a)es48
CMM Admin Ver 4.0(0.333)
Next are the phone model/quanity/firmware:
7902 2 CP7902060000SCCP050124A.SBIN
7911 25 SCCP11.8-3-3S
7912 18 CP7912080004SCCP080108A.SBIN
7920 2 CMTERM_7920.4.0-01-09
7936 13 CMTERM_7936.3-3-15-0
7940 87 P00308000800
7960 652 P00308000800 (P00306000400 OLD)
7961 288 SCCP41.8-3-3SR2S
7961GE 29 SCCP41.8-3-3SR2S
ATA 186/188 240 (including 2 ports) ATA030100SCCP040211A.ZUP
Inherited problem:
All devices were added to Publisher instead of Subscriber. Currently moving all devices to Subscriber.
Kelly Dodd Mon, 03/31/2008 - 12:08
Also should mention phone firmware was updated to latest revision, but the CM is still at version 4.0.2. Cannot see where ciscocm.4-0-2a-sr2b.exe was applied.
Management does not want to spend time and resources to upgrade up to version 4.3 at this time, looking to replace both CM's in coming year to v6.0.
Justin Brenton Mon, 03/31/2008 - 13:02
  • Silver, 250 points or more
Are these calls being initiated by a IP phone or analog phone connected to the ATA?
Is this happening to all phones? certain models? analog phones?
sounds like you have a one way audio issue. This is often network related but since you have made some upgrade's the first thing I would check is for any bugs with the CM version and firmware that you are using.
HTH, Please rate
Justin Brenton
Kelly Dodd Mon, 03/31/2008 - 13:09
This is happening on all IP phones (we use nothing but Cisco 79xx). The ATA's are used faxing, alarm control panels, etc.
