Is cisco's MST compatible with the standard 802.1s?
kangzhen
Hi, all
I tried to connect cisco 2950 and 4006 with other vender's device, say hp procure switch. but MST seems not compatible to each other. 2950 works fine with 4006, but treated hp's box as rstp neighbor.
i did google this forum and found some conversation about it. i just wonder it is a bug or not. if is, has it been fixed already?
#sh ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Sun 07-Nov-04 23:14 by antonino
Image text-base: 0x80010000, data-base: 0x8055E000
ROM: Bootstrap program is C2950 boot loader
j2950 uptime is 3 weeks, 1 day, 9 hours, 58 minutes
System image file is "flash:c2950-i6q4l2-mz.121-22.EA2.bin"
cisco WS-C2950-24 (RC32300) processor (revision J0) with 21055K bytes of memory.
Processor board ID FOC0711Z13P
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0D:BD:01:AC:00
Motherboard assembly number: 73-5781-11
Power supply part number: 34-0965-01
Motherboard serial number: FOC07291R9C
Power supply serial number: PHI072206LY
Model revision number: J0
Motherboard revision number: A0
Model number: WS-C2950-24
System serial number: FOC0711Z13P
Configuration register is 0xF
13 Replies 13
nambi_gct
In my experince it is fully complaiant with the standard.Have you configured the name, revision and instance consistently.Only if the MST region of the neighbor is different this will happen.
I configured the same region name on all boxes, create 2 instance and assign several vlan on each of them.
i can verify the configure by sniffer the STP packet. only difference between them is MST config digest and config id format selector. i can find the command to change that "format selector" and just wondered if it will affect MST behavior?
Cisco shipped MST before the standard was released. Your device is probably running this "pre-standard" version. I think 12.1 IOS only has the pre-standard version and some switches cannot upgrade to 12.2 and will be limited to this pre-standard version.
"Standard" Cisco bridges (12.2 and beyond afaik) are able to form regions with pre-standard ones. Third party bridges (or more broadly, switches that only implement the pure IEEE standard) won't be able to form a region with pre-standard Cisco boxes. You will be limited to RSTP use between those (you lose the ability to form a region, which means that you cannot do load balancing based on instances).
Francois
Francois,
thanks for your information.
since i don't have ver 12.2, I just tried to compare the "config digest" between 2 boxes.
even remove all vlan from instance and let all VID map to CIST, cisco's config digest does not match IEEE's standard (refer to IEEE 802.1s, table 13-2), but hp's box does.
zhen
Yes, and that's pretty much why you won't be able to form a region between a third party standard and a Cisco pre-standard box. You can only be part of the same region if the region name, revision number and configuration digest match. The key used to generate the configuration digest was released by the IEEE just when the standard was published (precisely for the purpose of preventing pre-standard implementation). Cisco provided its pre-standard MST several months before this event... Note that there are few other subtle differences between our pre-standard BPDU and the official one.
Anyway, as a result, pre-standard Cisco and third party standard switches can only share the CIST information. That's what's happening when the regions are different. So you can still run MST between the two types of device, but it's going to fall back to RSTP capability in the way that you can only use a single instance between them.
Francois
thanks again, Francois.
one more question is since cisco claimed 802.1s is supported long time ago, if we wanna purchase some box, how can i tell if pre-standard or real -standard 802.1s is supported? Because we need them to talk with other vendor's box.
zhen
Hi Zhen,
It's not really the platform but the IOS version that you need to check. The problem is that some old switches cannot be upgraded to a release that supports MST. As long as you can run at least 12.2, you are fine.
Francois
Francois,
Finally I got the box running 12.2. pls refer to the below info for details.
IOS (tm) s72033_rp Software (s72033_rp-PSV-M), Version 12.2(18)SXD7b, RELEASE SO
FTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 08-Dec-06 12:38 by ccai
Image text-base: 0x4002100C, data-base: 0x42040000
ROM: System Bootstrap, Version 12.2(14r)S9, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PSV-M), Version 12.2(18)SXD7b, RELEASE SO
FTWARE (fc1)
sw6509-bb2 uptime is 6 weeks, 4 hours, 7 minutes
Time since sw6509-bb2 switched to active is 6 weeks, 4 hours, 6 minutes
System returned to ROM by power-on (SP by power-on)
System image file is "sup-bootflash:s72033-psv-mz.122-18.SXD7b.bin"
cisco WS-C6509 (R7000) processor (revision 2.0) with 458720K/65536K bytes of mem
ory.
Processor board ID SCA042802D2
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
24 Virtual Ethernet/IEEE 802.3 interface(s)
144 FastEthernet/IEEE 802.3 interface(s)
66 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
after enable the MST, i still got the wrong message digest which is same as 12.1.
so is that build not NEW enough?
Thanks again
James
I thought you had some 29xx that were in 12.1?
Do a "show span summary". It should be clearly stated that this release is in an "IEEE standard" mode. I'm confident you'll get your sup720 to run MST standard!
Francois
Francois,
I had c2950 but can't find 12.2 for that platform.
below is the output of the command "sh span summary"
sw6509-bb2#sh spanning-tree summary
Switch is in mst mode
Root bridge for: MST03, MST05
EtherChannel misconfig guard is enabled
Extended system ID is enabled
Portfast Default is disabled
PortFast BPDU Guard Default is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default is disabled
UplinkFast is disabled
BackboneFast is disabled
Pathcost method used is long
Name Blocking Listening Learning Forwarding STP Active
MST00 0 0 0 105 105
MST03 0 0 0 4 4
MST05 0 0 0 4 4
3 msts 0 0 0 113 113
sw6509-bb2#
thanks for ur info.
James
James,
This one is not IEEE compliant it seems (it would be specified after "MST mode" in the output).
The cat6k release notes say you need 12.2(18)SXF or later:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/mst.html
Francois
Francois,
12.2(18)SXD7b is the latest one i can find so far.
i will let you know as soon as i got the chance to test the latest image you mentioned.
thanks anyway.
James
Sure. But don't take the one specified in the release notes, take the latest!
Francois
