DHCP Relay question
Answered Question
Mar 31st, 2008
Hello experts,
Hope you can help me with this scenario:
PC
(NM-16ESW)
c2691#1
(Fast0/0)
L2_Sw - PCs
(Fast0/0)
c2691#2
I have a DHCP pool configured in router c2691#2, which leases IP addresses to the PCs
attached to L2_Sw. I need to plug a PC on one of the 16 ports available in the NM-16ESW
module of the c2691#1 router and that PC should take an IP address from the DHCP pool
configured in c2691#2 router.
I have done a lot of configuration but I haven't had any luck so far. Is this possible?
Can somebody help me with the correct configuration of both routers?
Here is my last try:
c2691#1
ip dhcp relay information option
ip dhcp relay information trust-all
interface FastEthernet0/0
ip address 172.31.34.6 255.255.255.0
ip helper-address 172.31.34.2
duplex auto
speed auto
standby ip 172.31.34.1
standby priority 130
interface FastEthernet1/0
Description PC goes here!!!
duplex full
speed 100
spanning-tree portfast
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/15
interface Vlan1
no ip address
c2691#2
no ip dhcp use vrf connected
ip dhcp excluded-address 172.31.34.1 172.31.34.89
ip dhcp excluded-address 172.31.34.99
ip dhcp pool POOL
network 172.31.34.0 255.255.255.0
default-router 172.31.34.1
dns-server 172.16.3.100 172.16.3.101 172.17.4.11
lease 2
description CONEXION LAN
ip address 172.31.34.2 255.255.255.0
duplex auto
speed auto
standby priority 150
standby preempt
Thanks in advanced!!!
Juan Corrales
Network Specialist
ITS/FIFCO CR
Correct Answer by Karel Vins about 9 years 3 months ago
Could you connect router to switch via switch module? Use fa1/15 instead of fa0/0?
Overall Rating: 5 (2 ratings)
Karel Vins Tue, 04/01/2008 - 03:29
Hello Juan,
did you try to configure fa0/0 on c2691#1 as standard switched interface?
Karel Vins
Juan Pablo Corr... Tue, 04/01/2008 - 06:28
Hello Karel,
I cannot do that because I need f0/0 as a layer 3 interface doing HSRP with f0/0 of router 2691#2.
Juan Corrales
Karel Vins Tue, 04/01/2008 - 06:40
Hi Juan,
is it possible to use Vlan 1 interface as L3 interface instead of fa0/0?
Karel
Juan Pablo Corr... Tue, 04/01/2008 - 07:04
What's the configuration you're suggesting? Configure F0/0 as a trunk and use Vlan 1 as the L3/HSRP interface?
Karel Vins Tue, 04/01/2008 - 07:11
My suggestion is:
1) configure fa0/0 as switched access port in Vlan 1 and try if DHCP is working,
2) configure Vlan 1 as L3/HSRP interface.
I thing that fa0/0 can be access port not trunk port if you don't need more than one Vlan between router and switch.
Juan Pablo Corr... Tue, 04/01/2008 - 09:09
How can I configure a pure Layer 3 interface as an access switch port? I don't have any switchport commands available.
Karel Vins Tue, 04/01/2008 - 09:16
Ou, it's my mistake. I didn't realize that fa0/0 is not interface of switch module.
Correct Answer
Karel Vins Tue, 04/01/2008 - 09:29
