ephone dn not working
Answered Question
Mar 31st, 2008
Overall Rating: 5 (2 ratings)
Kenneth Mohammed Mon, 03/31/2008 - 14:26
  • Silver, 250 points or more
Is it possible you can paste the relevant parts of your configuration? Namely the configuration of your ephone-dn's and the ephones themselves.
Chuan Liu Mon, 03/31/2008 - 14:34
Here is the revelant configuration. This was working for months, and yesterday stopped working. No changes have been made to the system.
ephone-dn 10 dual-line
number 5580 secondary 099705580
preference 0 secondary 9
huntstop
no huntstop channel
call-forward busy 7989
call-forward noan 7989 timeout 15
call-waiting beep
hold-alert 30 originator
pickup-group 10
ephone 28
mac-address 0015.58CC.EA2E
type CIPC
button 1:10
multicast-moh
Always send media packets to this router: No
Preferred codec: g711ulaw
conference drop-mode never
conference add-mode all
conference admin: No
user-locale US
network-locale GB
Kenneth Mohammed Mon, 03/31/2008 - 14:41
Did you try to uninstall and reinstall the IP Communicator? The config looks OK to me. If this all of a sudden stopped working, then it could be an issue with the CIPC, not really too sure.
Chuan Liu Mon, 03/31/2008 - 14:46
I am using the Communicator to test the DN. I got the same results as with the physical phone. So it cannot be a problem on the phone. When another DN is assigned, the phone is working fine.
Kenneth Mohammed Mon, 03/31/2008 - 14:54
Are you getting a dial tone? What response do you get upon callout (busy signal, network message, etc)?
Kenneth Mohammed Mon, 03/31/2008 - 15:06
Not quite sure what could be causing the issue. Try removing the ephone-dn from the configuration, and then replacing and applying it to the ephone. You can also do a "show dial-peer voice summary" and see if you see a default dial peer with the destination pattern of 5580. I'm really just grasping at straws here. Also, one last thing, is this number on a PRI or is it a POTS line?
Chuan Liu Mon, 03/31/2008 - 15:13
Yes, the dial-peer is there on port 50/0/10.
It is on a 7912 phone directly connected to the cme.
Kenneth Mohammed Mon, 03/31/2008 - 15:15
Did you try to remove/replace the ephone-dn from the config and then try to reapply it to the ephone?
Chuan Liu Mon, 03/31/2008 - 17:58
I cannot remove this dn. An error message says
DN 10 has active call on interface 50/0/10 CH1
Cannot unconfigure
The problem might lie here. I have schedule a reload afterhours.
Correct Answer
Kenneth Mohammed Tue, 04/01/2008 - 06:29
OK..well let me know what happens.
Chuan Liu Tue, 04/01/2008 - 12:53
It is working now. That might be a bug.
Thanks.
Kenneth Mohammed Tue, 04/01/2008 - 12:55
Great..glad to hear it..sounds like a voice-port may have gotten hung up..
This used to be a pretty common problem in older versions and the
call typically could be cleared out by the "clear call voice" command after figuring out the ID.
I am now seeing it again in 12.4.24T3 unfortunately there isn't an identifiable call to clear in that release.  Happens to about 1 random phone every 1 to 2 weeks.  I think I will open a tac case on it.
bassa1985 Thu, 05/09/2013 - 17:26
Unfortunately that doesn't work for the issue on the new releases. I maintain ccme/uc500 systems across many different loads and this seems to happen on all of them from time to time. I don’t know for sure but I believe it happens if a phone is say on a call or ringing and it resets. Setting the lease time on DHCP to infinite has helped one site where I was having issues of course, I have never been able to induce the problem. I have only found 2 ways past it on newer 15+ releases.
2 options I use.
  1. Since you cannot delete the “ephone-dn xx” because it is in use remove the number from it. Then create a new “ephone-dn yy” and add the number to it. Swap the DNs on the phone, end user is happy, less disruptive then a reload and a lot quicker than TAC case.
  2. Only other way I found, Reload
bassa1985 Sun, 05/12/2013 - 02:55
Hi Jeckert,
Thank you for the quick reply.
I do like option 1, which I will perform tomorrow ..
However, if this happens again, we might have to look at a reload..( we have not performed a reload before and any instructions you would provide use would be appreciated)
Thanks mate.
