Can not ping host on LAN through VPN
Mar 31st, 2008
My problem is that I can connect to my office LAN via VPN and I can ping my default router there , but I can not ping any of the host machines attached to the my office's LAN. I'm thinking there may be an issue with an ACL but I have not been able to find it. I have attached my router's config> I hope some one can help.
Thanks.
johnd2310 Mon, 03/31/2008 - 22:16
Is it just ping that is not working? Can you rdp to the machines on your network?
John
robdawg01 Tue, 04/01/2008 - 04:52
I can ping all of the active interfaces, I can not map a network drive using the IP address. I'm not sure what you mean about rdp?
Randell
robdawg01 Thu, 04/03/2008 - 04:12
I'm still having problems with connectivity to my lan through the VPN. As I stated above I can ping the default router and all of theactive interfaces on the router, but I cannot ping or connect to any host or lan assests. I have attached an output of the remote router's config. Any help with this is greatly appreciated.
ciscosom Thu, 04/03/2008 - 10:02
Although i did not go through the entire Running config throughly , I think Router is assigning Ip address to it's remote VPN Clients with same subnet as that of LAN .I had similar issue and had to provide a diffrent Range (EG 192.168.3.0/24)for Vpn clients.And obvisouly you have to modifiy access-list for VPN client to be able to talk to your LAN Devices .
