logging a connecting pc's hostname
Mar 31st, 2008
We have a security requirement to obtain the hostname of machines connecting through our vpn devices. With logging on the local vpn client set to high I see it does log the systems' hostname (below.) Is it possible to capture this into my AAA servers to pass into our database?
101 19:19:56.497 03/31/08 Sev=Info/4 CM/0x6310003B
Address watch added for 192.168.79.105. Current hostname: LHOxxxxxxxxxFQC, Current address(es): 10.219.161.111, 192.168.79.105.
didyap Fri, 04/04/2008 - 14:04
Using vpn client the AAA server will authenticate a user on username basis and so it is not possible to log the machine hostname directly to the AAA server. Although you can send the syslogs to a syslog server and then later using some script you can serach for host names.
