Split tunnel question
Mar 31st, 2008
I have a ez vpn server 5505 and an ez vpn client 5505. I can tunnel so the vpn is working fine but at the remote site/ez client I cannot get split tunneling to work. Remote IP range is 10.1.112.0/24, I need to tunnel to 10.1.0.0/16 + 192.168.0.0/24 + 172.16.3.20/32. So what I have done through the gui is went to GP and then client config and then set split tunnel to tunnel network list below. I have then created one acl with all of the above listed IPs in an ace of permit. So I thought that would then force the rest of the requests out the 0.0.0.0 0.0.0.0 gateway. However this does not work either could someone please help or check my config to see where im going wrong. By the way the split tunnel is on the remote asa, not for sure if the split tunnel needs to be setup on the ez server or ez client, the client is where the workstations need internet access. Thanks in advance.
