Tandem Gateway VoFR/IP
Mar 31st, 2008
I've read some threads that indicate Tandem Gateway is not possible between VoIP and VoFR Dial Peers, but I thought I recall utilizing this configuration in the past. Does anyone know of any documentation that indicates whether or not this is possible?
For Example....RouterA--VoIP--RouterB--VoFR--RouterC
I can not find or think of any reason why this would not work. Anyone with a lab that could test this theory?
Also looking for VoIP Tandem Gateway documentation....anyone know of any?
Paolo Bevilacqua Mon, 03/31/2008 - 23:23
That doesn't work because you can't go from a VoFR leg to a VoIP leg directly. You must have pots interfaces in between.
Two E1/T1 PRI ports wit a cross-cable in the same router are ok for that.
