Cisco 2610 terminal server
Answered Question
Mar 31st, 2008
I got a terminal server with 2 octal cables attached to it. each octal cable has 8 RJ45 plugs. I installed a patch panel today and plug them into the back of the patch panel. I'll use the front panel as Out of Band ports.
However I can't access other device from my terminal server. I used rollover cable between the patch panel and my device. I was thinking maybe the octal cable is already rolled over. here are my partial output.
line 33 48
session-timeout 5
exec-timeout 5 0
flush-at-activation
no exec
transport input all
transport output none
escape-character BREAK
telnet ip-on-break
stopbits 1
flowcontrol hardware
AS05#sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 0 0 0/0 -
* 33 TTY 9600/9600 - - - - - 1 0 0/0 -
* 34 TTY 9600/9600 - - - - - 1 0 0/0 -
35 TTY 9600/9600 - - - - - 0 0 0/0 -
36 TTY 9600/9600 - - - - - 0 0 0/0 -
37 TTY 9600/9600 - - - - - 0 0 0/0 -
38 TTY 9600/9600 - - - - - 0 0 0/0 -
39 TTY 9600/9600 - - - - - 0 0 0/0 -
40 TTY 9600/9600 - - - - - 0 0 0/0 -
41 TTY 9600/9600 - - - - - 0 0 0/0 -
42 TTY 9600/9600 - - - - - 0 0 0/0 -
43 TTY 9600/9600 - - - - - 0 0 0/0 -
44 TTY 9600/9600 - - - - - 0 0 0/0 -
45 TTY 9600/9600 - - - - - 0 0 0/0 -
46 TTY 9600/9600 - - - - - 0 0 0/0 -
47 TTY 9600/9600 - - - - - 0 0 0/0 -
* 48 TTY 9600/9600 - - - - - 1 0 0/0 -
65 AUX 9600/9600 - - - - - 2 0 0/0 -
* 66 VTY - - - - - 7 0 0/0 -
67 VTY - - - - - 4 0 0/0 -
68 VTY - - - - - 0 0 0/0 -
69 VTY - - - - - 0 0 0/0 -
70 VTY - - - - - 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
1-32, 49-64
Correct Answer by mohammedmahmoud about 9 years 3 weeks ago
The octal cable is already rolled, you need a straight cable from the patch panel to your device, and your posted configuration seems fine.
BR,
Mohammed Mahmoud.
Overall Rating: 4 (2 ratings)
dmisell Mon, 03/31/2008 - 23:17
Wayne,
The following used to be recommended somewhere in CCO and is current:
http://www.conserver.com/consoles/msock.html
For something like a Cat 5500 you would normally use an OLD Style cisco headshell and straight through cable from the laptop. A router/asa would use a rollover.
Conversely you might use an octal into a back to back panel and patch a rollover into a 5500 switch and straight through into a router or modern ASA 5500.
The zeros are a bit of a giveaway and indicate negative comms, so check your patching, and look for the lights on the ASYN 32/16 or terminal server.
Hope this helps
kind regards
dave
[email protected]
Correct Answer
mohammedmahmoud Tue, 04/01/2008 - 01:05
  • Green, 3000 points or more
BR,
Mohammed Mahmoud.
