WCCP Debug Event
Mar 31st, 2008
I'm implementing a transparent proxy using bluecoat. It uses WCCP between bluecoat and 3560.
Now it's working (the HTTP packet is redirected to the bluecoat), but when i do "debug ip wccp event", it shows these messages :
May 7 08:27:46.105 SGT: WCCP-PKT:D10: Sending I_See_You packet to 10.2.4.129 w/ rcv_id 00000058
May 7 08:27:56.112 SGT: WCCP-EVNT:wccp_update_assignment_status: enter
May 7 08:27:56.112 SGT: WCCP-EVNT:wccp_update_assignment_status: exit
May 7 08:27:56.112 SGT: WCCP-EVNT:wccp_copy_wc_assignment_data: enter
May 7 08:27:56.112 SGT: WCCP-EVNT:wccp_copy_wc_assignment_data: reuse orig mask info (1052 bytes)
May 7 08:27:56.112 SGT: WCCP-EVNT:wccp_copy_wc_assignment_data: exit
May 7 08:27:56.112 SGT: WCCP-EVNT:wccp_validate_wc_assignments: enter
May 7 08:27:56.112 SGT: WCCP-EVNT:wccp_validate_wc_assignments: exit
May 7 08:27:56.112 SGT: WCCP-EVNT: L2 adjacency added for 10.2.4.129
May 7 08:27:56.112 SGT: WCCP-PKT:D10: Sending I_See_You packet to 10.2.4.129 w/ rcv_id 00000059
May 7 08:28:06.111 SGT: WCCP-EVNT:wccp_update_assignment_status: enter
May 7 08:28:06.111 SGT: WCCP-EVNT:wccp_update_assignment_status: exit
May 7 08:28:06.111 SGT: WCCP-EVNT:wccp_copy_wc_assignment_data: enter
May 7 08:28:06.111 SGT: WCCP-EVNT:wccp_copy_wc_assignment_data: reuse orig mask info (1052 bytes)
May 7 08:28:06.111 SGT: WCCP-EVNT:wccp_copy_wc_assignment_data: exit
May 7 08:28:06.111 SGT: WCCP-EVNT:wccp_validate_wc_assignments: enter
May 7 08:28:06.111 SGT: WCCP-EVNT:wccp_validate_wc_assignments: exit
May 7 08:28:06.111 SGT: WCCP-EVNT: L2 adjacency added for 10.2.4.129
May 7 08:28:06.111 SGT: WCCP-PKT:D10: Sending I_See_You packet to 10.2.4.129 w/ rcv_id 0000005A
May 7 08:28:16.111 SGT: WCCP-EVNT:wccp_update_assignment_status: enter
May 7 08:28:16.111 SGT: WCCP-EVNT:wccp_update_assignment_status: exit
May 7 08:28:16.111 SGT: WCCP-EVNT:wccp_copy_wc_assignment_data: enter
May 7 08:28:16.111 SGT: WCCP-EVNT:wccp_copy_wc_assignment_data: reuse orig mask info (1052 bytes)
May 7 08:28:16.111 SGT: WCCP-EVNT:wccp_copy_wc_assignment_data: exit
May 7 08:28:16.111 SGT: WCCP-EVNT:wccp_validate_wc_assignments: enter
May 7 08:28:16.111 SGT: WCCP-EVNT:wccp_validate_wc_assignments: exit
May 7 08:28:16.111 SGT: WCCP-EVNT: L2 adjacency added for 10.2.4.129
May 7 08:28:16.111 SGT: WCCP-PKT:D10: Sending I_See_You packet to 10.2.4.129 w/ rcv_id 0000005B
It's repeated every few seconds.
Is it a behavior of the WCCP to add the L2 adjacency to the appliance constantly ? or is it an error ?
Thanks and Regards,
Richard Kristian
Zach Seils Wed, 04/02/2008 - 04:15
  • Cisco Employee,
Richard,
Can you collect a packet capture of the WCCP communication between the proxy and the switch? From the debug output, it seems that the proxy is updating the assignment information every 10 seconds.
Zach
RichardKristian_2 Wed, 04/02/2008 - 04:45
Hi Zach,
Thanks for the reply.
Unfortunately, i don't have access to the network at this moment. By the way, is there any issue if the proxy keep updating the assignment information every 10 seconds ?
Richard
Zach Seils Thu, 04/03/2008 - 14:08
  • Cisco Employee,
Generally this isn't a problem, since most of our platforms will ignore duplicate assignments.
Zach
