paolo bevilacqua Tue, 04/01/2008 - 08:14
  • Hall of Fame,
    Founding Member
You can use a 2801 with ccme license that support up to 30 phones, then you config B-ACD/AA that allows you to have multiple hunt groups, call queuing and statistics, basically everything you need for a simple and efficient call canter.
Rick Morris Tue, 04/01/2008 - 08:41
  • Silver, 250 points or more
great answer to the point...5 points!
Also, would you have any links that you know of to help point in the right direction? I don't have a need today but maybe in the future to set this up.
Rick
