CVOICE exam
Apr 1st, 2008
Ive recently completed the CVOICE v5.0 course for the exam 642-432 CVOICE.
Its not clear via the website or tracking tool, if I take that exam rather then the new 642-436 if it applies to BOTH CCVP tracks.
Can anyone confirm ?
rodmont74 Tue, 04/01/2008 - 16:01
Hi, in a short answer yes. I'm similar situation completed some exams. Cisco usually allows mixing requirements which are similar, so I believe you do not need to pass on CVOICE6 again, v5 is enought.
New CIPT 1 and 2 for CUCM 6.x consolidates GWGK content so I would take care to not do redundant exam content. I intend to go on GWGK this month and CIPT4 after which I have experience. I don't know I will be ready to do CIPT5 until it's decomissed near august.
If you want to go with CVOICE 5 and newer content and exams, you get the advantage of learning newer product versions like CUCM6 and less content in GWGK. Good luck.
