CiscoIPPhoneExecute with C# Application Form - Error #4.
Apr 1st, 2008
Hi !
I'm trying to build a new windows application form with C#.
This application will load all the IP Phone found into the call manager and will let the possibility to CALL them.
I have a BUTTON with "CALL" label, and when i press it, it must CALL the phone selected with my OWN IP Phone. (near my desktop computer, which i'm Owner).
Here is my code :
String XML = "<CiscoIPPhoneExecute><ExecuteItem URL=\"Dial:1010\" /></CiscoIPPhoneExecute>";
HttpWebRequest webRequest = (HttpWebRequest)HttpWebRequest.Create("http://10.1.100.24/CGI/Execute");
webRequest.Method = "POST";
webRequest.Credentials = new NetworkCredential("myActiveDirectoryUsername", "myPassword");
byte[] byteArray = Encoding.UTF8.GetBytes(XML);
webRequest.ContentType = "application/x-www-form-urlencoded";
webRequest.ContentLength = byteArray.Length;
Stream dataStream = webRequest.GetRequestStream();
dataStream.Write(byteArray, 0, byteArray.Length);
dataStream.Close();
HttpWebResponse response = (HttpWebResponse)webRequest.GetResponse();
When i'm sniffing the network, i recieve a CiscoIPPhoneError 4.
<CiscoIPPhoneError Number= "4" />
How can i do to make a IP Phone call another ?
ALL MY IP PHONE INTO MY CALLMANAGER HAVE OWNER USER ID = Owner From ACTIVE DIRECTORY.
I must use this login & password ?
How could i solve it ?
Thanks !
stephan.steiner Tue, 04/01/2008 - 02:04
  • Silver, 250 points or more
The documentation mentions the following:
Error 4 = Authentication error
Is the endUser "myActivedirectoryUsername" associated with your phone?
stephane.lhp Tue, 04/01/2008 - 02:18
Yes, the Error 4 is an Authentication Error.
Actually, my CALL MANAGER 6.x is configured with my ActiveDirectory, and ALL USERS from AD are associated with a IP Phone in the Call Manager.
---> Yes !
It's my own Active Directory LOGIN and i use my Active Directory PASSWORD to build the CREDENTIAL.
Still have this error :(
stephane.lhp Tue, 04/01/2008 - 04:45
I've still this authentication problem.
The Owner User Id + his own password doesn't work !
What are the information of authentication i need to send with the PUSH command Execute ?
I see many problems similars as mine havent been solved.
Someone told me i need to use "PIN" field with username, and not the password field !!!
But what's the PIN when the callmanager end user's are whose in the ActiveDirectory controler ?
Thanks in advance ...
stephane.lhp Tue, 04/01/2008 - 06:03
Problem Solved :
I created a new APPLICATION USER in the CCM.
I gave him ALL ACTION ALLOWED to all the IP PHONE registered in the CCM.
(Access to all ip phones).
Now, i use his login and password to pass the credential.
It's ok, i can push xml.
fgasimzade Thu, 07/31/2014 - 08:14
Dear Stephane.lhp
I have the same problem. Can you pls tell me which groups you used to add to the application user?
Thank you
