massimiliano.se... Tue, 04/01/2008 - 03:03
"The show processes cpu history command displays in ASCII graphical form the total CPU usage on the router over a period of time: one minute, one hour, and 72 hours, displayed in increments of one second, one minute, and one hour, respectively. Maximum usage is measured and recorded every second; average usage is calculated on periods over one second."
Reference: http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_tech_note09186a00800a65d0.shtml#showprochistory
Massimiliano.
guruprasadr Tue, 04/01/2008 - 03:05
HI, [PLs Rate if HELPS]
You can execute:
router#show processes cpu sorted 1min
Display top-10 CPU-intensive processes on a router ...
Pls Rate if hELPS
Best Regards,
Guru Prasad R
mohammedmahmoud Tue, 04/01/2008 - 03:28
To add a very small detail, the 'show process cpu history' command is available in IOS 12.2 and higher.
BR,
Mohammed Mahmoud.
