04-01-2008 01:38 AM - edited 02-21-2020 01:57 AM
there's no mention of QoS in the data sheets for the PIX 501 or 506 but there is for the 515. The PIX OS 7.x configuration guides don't mention specific hardware support.
Does anyone know if QoS is supported in the 501 or 506e - I need to support Priority Queuing for VoIP over IPSec.
Chris
Solved! Go to Solution.
04-01-2008 04:05 AM
QoS is supported in code 7.x, you would have to upgrade 501/506 to code 7.x but this is not supported on these two models, the next logical solution would be to upgrade your 501/506 pixes to asa5505s.
Rgds
Jorge
04-01-2008 04:05 AM
Rgds
Jorge
