dspfarm maximum session problem
Answered Question
Apr 1st, 2008
I am currently setting up a 2620 IOS gateway with an NM-HDV to give my company some additional Transcoding & Confbridge resources.
Due to the memory limits and the IOS l can only configure the basic commands for the DSP Farm (see URL)
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml#backinfo
Going by the example in the URL above with the amount of DSP in the NM-HDV in the router we should be able to configure 3 Confbridges & 12 Transcoding sessions. But when the configuration is applied to the router l can only configure 1 Confbridge or 4 Transcoding sessions -
DSP_VG#DSP_VG(config)#dspfarm transcoder maximum sessions ?
<1-4> Specify the maximum transcoding sessions value
DSP_VG(config)#dspfarm confbridge maximum sessions ?
<0-0> Specify the maximum conferencing sessions value
I have also applied this configuration to a 2620XM router using 12.4 IOS Train and had the same results.
Any suggestions?
Correct Answer by Jaime Valencia about 9 years 3 weeks ago
are you aware that your E1 also takes resources from that pool?
if you look at the show voice dsp you can see 32 channels are already allocated for the E1
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
C549 007 01 {medium} 4.1.46 IDLE idle 0 0 1/0:15 01 0 0/0
what you get to configure is what's free of those resources, if you need more sessions add more PVDMs, there are still 2 slots available
SIMM slot 0: Empty.
SIMM slot 1: Empty.
SIMM slot 2: PVDM-12 SIMM present.
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 04/01/2008 - 11:25
  • Cisco Employee,
  • Hall of Fame,
    2011
SIMM slot 0: Empty.
SIMM slot 1: Empty.
javalenc
JAMES WEST Wed, 04/02/2008 - 00:31
Hi Javalenc,
Thanks for getting back with the info you provided above, worked a treat.
James
