Serial Number of a Cisco router
Apr 1st, 2008
What is the Cisco CLI command to be used to find the serial number and model number of a cisco equipment?
Please guide me.
Thanks and Regards,
S.Venkataraman.
Overall Rating: 5 (2 ratings)
guruprasadr Tue, 04/01/2008 - 03:12
HI Venkat, [Pls Rate if HELPS]
Execute below commands:
sh version
>> To verify the Model No # and IOS Software installed currently.
sh inventory
>> Provide the Serial No # of the Equipment and the other accessories installed.
Pls Rate if Helps
Best Regards,
Guru Prasad R
Richard Burts Tue, 04/01/2008 - 04:34
S.Venkataraman
Guru has given two commands which MAY provide the correct information. Unfortunately neither command works consistently to provide the serial number. In particular I would be careful about the show inventory command. In my experience it produces the correct serial number on some routers (especially the ISR series of routers) but on other routers it produces output that is not the serial number. Before I execute the show inventory command on a remote router and trust the output, I would suggest trying it on a router of that model where you can physically verify the output of show inventory.
Rick
Danilo Dy Tue, 04/01/2008 - 04:42
I agree with Guru and Rick.
If you can physically access the router, better compare both CLI and physical label.
I mentioned this because I experienced having 2 PIX Firewall in which the physical label interchanged :)
FW1
Physical label: XXXXXXXXXX02B
CLI: XXXXXXXXXX01A
FW2
Physical label: XXXXXXXXXX01A
CLI: XXXXXXXXXX02B
Common sense dictates that the CLI is correct :)
Dandy
cisco_lad2004 Tue, 04/01/2008 - 11:14
some times it is platform Dependant.
4500 for example use "show idprom chassis"
