SIP - registering a E1
Hi! I have a problem with my ISP and SIP commiucation.
[ISP]---[2811]---e1---[PBX]
Incoming call (SIP) come to me from ISP, my router translate call to PBX (e1 channel). But - I have a problem with registering PBX-number on a ISP side. If I have a ephone with requared number - no problem with calls, my ISP say that my phone registered successful, but - if I assign this number to pots E1 - It can't be registered.
My config is:
sip-ua
authentication username 5555555 password 1111
registrar ipv4:10.10.10.5:5060 expires 3600
sip-server ipv4:10.10.10.5:5060
dial-peer voice 1 voip
descrip =TO-ISP=
destination-pattern .T
session protocol sipv2
session target sip-server
session transport udp
dtmf-relay h245-alphanumeric
codec g711alaw
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
dial-peer voice 1 pots
destination-pattern 5555555
no digit-strip
direct-inward-dial
port 0/2/0:15
mchin345 Mon, 04/07/2008 - 06:23
For SIP registering, there will be a new CLI 'sip-register' or 'no sip-register' that will do the job. Try this
