Unity options
Apr 1st, 2008
  • Silver, 250 points or more
I`m looking for options with regards to Unity as the Unit is not the current VM system. I`m aware of Unity only , Unity UM with Notes etc but I need some options on the two. I do not want to go full UM yet but I`m looking for justification for Unity only - any adds-ons to push the Unity only case.
Can you have a Unity UM system with Notes at a central Site for some users but not all - Mixed Mode if there is such a thing
Is there any applications which allow a user to have voice mails to a Web Client without having full UM so the Unity is still stand-alone and not integrated into any UM environment
Blackberry integration- I know Exchange has this via a BES plug in but again can you have the same feature in a stand-alone situation- Users email is currently not exchange
If you have UM, does the admission of a user still sit with the Unity or is it 100% handed over to the email team- user set up, COS, Deletion, Password resits etc
In Unity connection there is a IVR directory - Is this available in full Unity ?
Main differences- pros- cons between Unity and Unity connection
Any click to dial built in ?
many thanks
