CUCM 6.0.1.2116-1 - Time setting option - Jan to May missing
Hi All,
Has any one come across the following time settings issue on the above mentioned version of CUCM:
Click on Settings>Time
First 3 columns show _ instead of the months, for example for the first 6 options you see _ instead of the months Jan to May, but can see options available for June to December.
Similar issue on the Year, Year begins from 2010 and no option available for 2008 just _.
Just wanted to know if anyone has come across this before I go about raising this with Cisco TAC.
I've attached a screenshot for your perusal.
Thanks in advance,
Asim
cuevas Tue, 04/01/2008 - 05:45
Do you have an NTP Server set??? I've seen this when you have an NTP Server entered into Call Manager
