LMS 3.0 duplicate devices?
Apr 1st, 2008
  • Gold, 750 points or more
I have an evaluation version of LMS 3.0 running on a server as a test. I have a small number of IOS devices (and a CallManager 4.2 server) which I originally put into a .CSV file and imported into LMS 3.0. I used the hostnames (FQDN's) in the .CSV file as all the hosts are registered in DNS. I noticed today that there are now duplicate entries for each device, one with the original FQDN and a duplicate that just has the hostname - i.e. '3560-switch.testlab.local' and a new one called '3560-switch'. I have checked and this is in Common Services and has been exported to RME etc. The server's DNS suffix is the same as the devices (testlab.local).
Is this normal behaviour? and is it correctable?
Cheers
Andy
yjdabear Tue, 04/01/2008 - 07:50
I had almost the identical issue when I upgraded from LMS 2.2 to 2.6. I recall the dupes were a result of Campus Manager "Device Discovery" exporting to DCR (by default). In LMS 3.0, I think the checkbox to turn off this synchronization is somewhere in DCR now. I don't think LMS helped much with deduping. It probably involved exporting the DCR inventory to a csv and awk/sed away the dupes, although one could try making the dupe pairs identical in every way possible Identity-wise in DCR and then hope DCR/RME starts realizing the dupes on its own.
Joe Clarke Tue, 04/01/2008 - 10:06
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Is this LMS 3.0.1? Are you using Common Services Discovery? If so, you are probably hitting CSCsm66330.
andrew.butterworth Tue, 04/01/2008 - 10:54
Yes, its running whatever are the latest patches - Dec 2007 patch applied plus whatever is on CCO. I have just had a quick look at the BugID and it looks more like a behaviour issue as opposed to a bug. Is it because the names resolve to the same Domain Suffix as the server?
Andy
yjdabear Thu, 04/03/2008 - 08:23
The bug describes a dupe scenario where a device is known by its IP addr and its hostname once each. Does it also apply to the "hostname"+"hostname.fqdn.com" dupe scenario?
Joe Clarke Thu, 04/03/2008 - 09:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes. Any instance where the device is in DCR by one name/address, but Discovery determines it needs to manage the device by another name/address, the device will be duplicated in DCR.
